Help, D-lock Mmm... locked!
scotty110788
Tyne and Wear
I got new D lock from halfords a week ago, only ever tied my bike up in secure car park so weather aint got to it, but it has seized up while in car park (Had to take what people call a "bus" home, square box on 4 wheels, anyway...) tried wd40 and little oil, and about half hour trying to get off but key just wont go more than half a turn, halfords said they ill exchange it but have to take it off 1st, its grade 10 rating, any ideas?
stoofer
Cut it off. Takes seconds with a big enough chopper.
Have you taken the key out properly and all the cylinders in line. Never force a key, they snap. Try wiggling the key in rotating a little side to side to ensure it goes all the way in.
jay clock
Massive member
Hampshire UK
So it sounds like the lock is only attached to the bike? If so, cut through the cable, then take the whole bike plus lock to Halfords for them to solve. Probably worth taking a friend to check you are not using the key wrong first or summat!
If you have only locked the lock to the bike, then you are not using it properly - you should have the lock round the frame plus something solid
Best of luck!
scotty110788
scotty110788
Tyne and Wear
Only a small D lock, getting bigger next week to lock around something solid, using 2 other locks in mean time to keep it safe which i'm glad, do come off. good point, gonna get them to do it haha
NormanD
Lunatic Asylum Escapee
Tap the lock section with a hammer or spanner, it might release the pins if they're stuck
Titan yer tummy
No meatings b4 dinner!
If you do take it to halfords to sort out I would suggest you take a picky of it first. Particularly the area where they are going to apply leverage. Then if they do do damage your bike you have the evidence if it comes to a claim.
Night Train
Maker of Things
Are you sure no one has messed with it?
Lots of careful wiggling of the key should be able to tell you if there is any movement in the pins/tumblers inside.
Tapping and WD40 does help, sometimes.
If the key is turning, even a part of a turn, then the lock barrel is fine. It is possible the locking pin is stuck so adding lube to the two points where the loop enters the locking bar and then tapping the ends and the locking bar onto the loop might free it.
funnymummy
A Dizzy M.A.B.I.L
I have the same lock, I use it to lock my sons bike to mine.. Are you using the main large fobbed key..? I had probs with mine, tried one of the smaller spare keys & it opened immediatly.
Sadly this meant we push our bikes the 9 miles home as couldn't sepearte them.. Ever tried pushing a XL framed bike in unison with a small childs mtb...? Lots of cursing under my breath & several large drinks that evening!!
Banjo
Fuelled with Jelly Babies
South Wales
I opened a stuck padlock this week by pouring boiling water over it on the recommendation of a friend. Worth a go.
