dmoura
- Porto, Portugal
Hi,
I think I’ve got long legs for my height, which is making me difficult to choose the size of my new bike. I am 5’11’’ tall with 34.4’’ inseam. I plan to buy a Kona Honky Tonk, but I am having difficulties choosing between sizes 56 and 59. I’ve run the fit calculator from www.competitivecyclist.com and I’ve confirmed that the "perfect" frame would have a seat tube pretty much longer than the top tube.
My Measurements (cm)
Inseam: 87.5
Trunk: 59.5
Forearm: 38.5
Arm: 67
Thigh: 60
Lower Leg: 56.8
Sternal Notch: 148
Total Body Height: 180
The Eddy Fit (cm)
Seat tube range c-c: 57.9 - 58.4
Seat tube range c-t: 59.6 - 60.1
Top tube length (TTL): 55.9 - 56.3
Stem Length: 10.4- 11.0
BB-Saddle Position: 80.3 - 82.3
Saddle-Handlebar: 55.5- 56.1
Saddle Setback: 6.4- 6.8
Kona Honky Tonk (cm), http://www.konaworld...tent=honky_tonk
Size C-T TTL STAng StandOver HeadTube
56 54.0 56.5 73.5° 78.7 15.0
59 57.0 58.5 73° 81.3 17.0
Size 56 seems to provide the best Top Tube Length, while size 61! would be the best according to the suggested seat tube.
The Kona distributor suggested size 56 (by e-mail), and in most of the bike stores the staff says that I should be a 56 (for road bikes in general). However, I am afraid that size 56 may make me raise the saddle too much and increase the height difference between saddle and handlebar, making it unconformable, especially for my neck and arms while commuting… On the other hand, the bike does seem to come with 5cm of headset spacers (http://www.bikeradar...-tonk-10-38691/)...
Increasing to size 58 will make the top tube >2cm longer than suggested, but that may be compensated by using a shorter stem, right? Additionally, since the ST angle decreases 0.5º, (a small) part of the increase in the top tube length goes behind the pedals…
If I had to choose between aggressive vs comfortable position on the hoods I would go for comfortable (I plan to use the bike mainly for commuting, light touring, and fitness). In fact, having a comfortable riding position is one of the reasons for buying a new bike, but I can’t find any dealer with this model in stock…
Summing up, dealers suggest 56 by e-mail based on my height but for me (not an expert!) 58 and a shorter stem seems better... any opinions?
Many thanks in advance.
Inseam: 87.5
Trunk: 59.5
Forearm: 38.5
Arm: 67
Thigh: 60
Lower Leg: 56.8
Sternal Notch: 148
The Eddy Fit (cm)
