BSOh
- Ceredigion
Hi all
Being so short, I ride a junior cx bike which has 650a wheels (currently with 37mm Schwalbe delta cruisers - one of the limited selection I can get for this size wheel). This wheel-size I think is not common (same as the old English 3 speed?).
My first question is mudguards - does anyone know if there will be a problem fitting the nearest to size mudguards, for example 650b (650b as I understand it is 6mm smaller diameter - 584mm vs 590mm).
My second question is wheels - Could I put a more popular wheel-size on? Presumably brakes would be a problem? (This is probably hypothetical as the bike is not worth spending that much on).
My third question is brakes - the bike has Kore canti brakes. They squeak like mad, and there's awful judder when wet. They don't fill me with confidence. I have read loads of remedies online - that some people swap to mini v's, long drop's etc but I'm not sure whether a) its worth it and it will make a difference or b) I can do it on my bike (fyi it has junior specific 9 speed Microshift sti shifters). Others say decent pads make all the difference. Any opinions on the best solution?
Any advice you can offer will be much appreciated
TIA
BSOh
TIA
BSOh
