Primal Scream
Get your rocks off
- On the road to hell
Is there any legal reason or for that matter any other reason that I should not fit a small light on the back of my cycle helmet?
A good point, however unlike m/cycle helmets which are designed to slide along the ground and not to apply twisting forces [the speeds involved being much greater] a cycle helmet is more of a "bonk" absorber and a small LED shouldn't really cause much of a problem, although I do agree the smaller rubber types may be the best to use.You might think about why you are putting a helmet on your head and then whether strapping something hard and sticking out onto the outside is a good idea if you have an accident.
