So I bought a cheap helmet cam off the internet. Trouble is it only does 20 minutes on a pair of AAA batteries which is rubbish.
So I've made up a 3 volt battery pack by connecting two twin AA battery holders in parallel and soldered it to the existing battery connections. Now it runs for about 3 hours!
Because I'm lazy, I can't be ar*ed to pull out all the batteries and put them in a standard charger every night, so I want to charge it as one unit.
Do I:
A) butcher a standard battery charger which'll give me the correct voltage, but an extrodinarily long charging time (the battery pack is essentially 10000 mAh. The charger output is 280 mA for a pair of AA's, resulting in a charge time of 35 hours!!)
B) Butcher a standard battery charger, connecting the two sets of 3 volt outputs in parallel, theoretically giving me a 560 mA output, halving the charge time to 17.5 hours. (or is that not quite how it would work?)
or
C) buy a dedicated battery pack charging unit. I have found chargers rated at 4.2 volts, but I'm unclear whether this is the output voltage (which would be about right for a 3 volt setup), or whether they're designed to charge a 4.2 volt battery pack (in which case I would have thought the output would be 5.5 - 6 volts, which'll be too high).
Any thoughts anyone?
Do I:
or
