Helmet Advice
ian emmerson
Quite recently i have had the misfortune to have had some brain surgery following an accident, fortuneatly a full recovery is expected.
I am hoping to be allowed to cycle again soon and although my helmet is very new ( 7 days prior to accident) i am looking at tips from you guys as to what you suggest i could use to increase comfort whilst wearing it,
Have read in the past buff, skullcap etc.
Any suggestions ?
Sorry to be negative......
The fundamentals of comfort re in the design and fit
It is very difficult to make a helmet comfortable if these basics are wrong
Deleted member 26715
If you were wearing that particular helmet at the time of the accident & you suffered head injury then the helmet will have been damaged, throw it in the bin & buy a new one.
Alan...
Hi,
At much at it hurts to say this my opinion is throw it away and buy a new one because I an of the school of thought that is as soon as a helmet is involved in an accident it is no longer as structurally sound so no guarantee it will work as effectively 2nd time round!
Nigeyy
I would -if you haven't already -consult your physician or specialist related to your injury. You want to make you are receiving the right advice!
Any suggestions ?
Depending what kind of surgery you had, I'm not sure I would be getting back on my bike until I had been fully signed-off by the neurosurgeon. The last thing you probably want right now is the risk of another impact in the same area.
ScotiaLass
Middle Earth
I could never find a helmet that was comfortable for me.
I've just bought a new Bern helmet......worth every penny! You can buy a winter liner too so it's ideal for the really cold days.
drewc65
bristol
Have to go with the lass on this one. Bern helmet with a winter liner is the dogs nuts. Belive you can even get a liner with built in headphones and they do some really tidy colours. They almost like a skull helmet they use for horse riding but have a removable peak. Makes you feel a bit more secure as well
Mr Haematocrit
msg me on kik for android
What makes you believe this, Bern helmets are rubbish imho
As someone who has suffered a head injury, if the OP does look at getting a new helmet they should look at the safety standards the helmet is certified by.
The most difficult certification to obtain is the cycling specific SNELL B90A standard which a lot of helmets including those made by Bern do not meet.
The only requirement to sell a helmet suitable for cycles in the UK is to pass the EN 1078 which is the same standard used to certify a helmet for use with roller skates.
The standard's key features of the EN 1078 test are
  • Test anvils: Flat and kerbstone
  • Drop apparatus: Guided free fall
  • Impact velocity, energy or drop height flat anvil: 5.42–5.52 m/s
  • Impact energy criteria: < 250g
  • Roll-off test: Yes
  • Retention system strength: Force applied dynamically. Helmet supported on headform.
The anvil tests are square on strikes which you are unlikely to come across in a cycling accident, it would also be fair to suggest imho that a cycle can travel at a faster constant speed than roller skates which also uses the EN 1078 to certify the helmets.
Bern Helmets are known for poor impact protection
http://bikeportland.org/2012/05/31/...oor-impact-rating-from-consumer-reports-72616
the Brighton Thin Shell EPS from Bern came in well behind the seven other adult helmets in the test. The Nutcase model received a total score of 14 out of 100, while the Bern got a 13. These two helmets were the only ones in the test (which also looked at four youth helmets) to receive a "poor" rating in the "impact absorption" category.
SHornswaggle
Harden the ____ up
Kent, UK
Technically I don't much about helmets but I have the Specialised Prevail and I can honestly say that (unless I use the helmet cam) I do not know that it is on my head at all.. It is light and the adjustment bits means it fits well with no slipping.. It arrived in a big box with pads in too for me to stick where I wanted (don't go there!!)
