Enso108
Formerly OselLing
- Highlands and Cumbria
I decided to take the ridgeback off the turbo and give it a quick run out as it was a cracking dry day. I had to take the home trainer tyre off and refit the original tyre, I managed to snap a tyre lever getting the tyre off, I re inflated the tyre and refitted the wheel to find it wouldn't keep pressure, so off with wheel then the tyre to find a hole in the inner tube. So I repaired that and stuck the tube and tyre back on the rim, pumped it up to the recommended 60 psi, I was just refitting the wheel when BANG! the tube exploded blowing the tyre right off the rim! After a quick check of the pants to make sure everything was all in order I decided to take the winter bike out for a quick spin. What could have caused that, a pinch in the tube?
I'm normally expecting the lidl's pump to explode not the tube.
