following on from the 'how fit are you' thread in cafe, it's sort of occurred to me that your actual heart rate might be fairly important, and that I should probably be striving to get it as low as possible. Moreso, the fact that it can be measured digitally using a device effectively enables you to quantify fitness, making it a lot easier / more rewarding to get fitter as you can see how much fitter you've got.
So, how important/significant is it, and is it all to easy to get too obsessed with heart rate when you should be thinking about other measures aswell? obviously your weight, and how fast/far you can go is an indicator, but any other little numerical physical things you can measure to go with heart rate?
