Upgrading steel frame racing bike very soon.
Even if I was not doing so, headset is a bit notchy currently. I believe I require a 1 inch headset. I will be using the upgrade to add carbon forks. Is there anything I should know about this process ? What sort of headset would be advisable ? I will be doing most of the work on the upgrade BUT I will be using a LBS to fit the headset. Would I much notice the quality diff from a Campag Chorus h/set ( at about £45 - £50 or so ) and the superstar Chris King ( at the £110 or so mark ) ??? Ta very much for any and all comments.
