- the post-brexit wasteland
are you sure the headset is loose?my ribble cgr sl ‘rocks’ slightly with front brake applied.
i’ve tried tightening the headset with the bolt through the top cap, but makes no difference.
anything simple that can be done before i hand it over to the lbs to fix?
Not wishing to teach you to suck eggs but have you undone the two side pinch bolts before trying to tighten the top cap?my ribble cgr sl ‘rocks’ slightly with front brake applied.
yes, did the pinch bolts (always a good thing to call out just in case). it’s a carbon steerer so assume it has some sort of expansion bolt rather than a star nut. could that be the same issue?Not wishing to teach you to suck eggs but have you undone the two side pinch bolts before trying to tighten the top cap?
It could be the star fangled nut inside has pulled up in the headset and needs to be knocked gently down again.
You’ll only know by looking. It might worth checking with you LBS if unsure.yes, did the pinch bolts (always a good thing to call out just in case). it’s a carbon steerer so assume it has some sort of expansion bolt rather than a star nut. could that be the same issue?
will try that. ordered a set of carbon spacers so bike will get a small upgrade. had to do the same with another bike following a vanity change of top cap...Try putting an extra spacer under the cap - you may be at the limit of the bolt?
put a 2mm spacer under the cap and that worked 👍Try putting an extra spacer under the cap - you may be at the limit of the bolt?
