That link doesn't work - try using the chain sybol next to the smilie or the image box next door.
Ah - with you now Macka.
That is a bung for a carbon steerer with what looks like a top-cap bolt threaded in it.
Simply undo the bolt with a hex key, pop the spacers and stem on and then put the bolt you have removed through a top cap and then thread it back into the hole from whence it came.
If that does the trick - don't tighten anything yet - come back to the forum for directions on how to tighten up!Unless of course you know what you are doing.
Here's a (bit small) diagram of how it should all work
http://t2.gstatic.co...culi4BSL36g&t=1
and http://www.sheldonbr...-threadless.jpg
If I get this right - the bit sticking up has a thread inside it for the top cap and bolt to screw into.
I don't know the type of bung but some have a 5mm hex slot under the thread for tightening and undoing the bung - try sticking a hex key down there to see if anything engages.
