Headset spacers smaller outer diameter than stem
Welsh wheels
Lycra king
South Wales
Hi, I haven't posted on Cyclechat for ages, but am in need of some advice. I was advised to fit a longer stem to my bike after a bike fit at my lbs. The stem they sold me was a Giant contact but had a larger diameter than my aluminium steerer tube, so they fitted a steerer tube shim to reduce the inner diameter. Now, a few months on I am experimenting with dropping the bars a couple of spacers. Only issue is that the spacers on top have a smaller outer diameter than the stem that they sit on top of. Is this likely to be a problem and is it safe to ride with? Picture attached.
532536
Teamfixed
Tim Lewis
Looks like the top cap had that diameter therefore covered the top of the stem.
I imagine then that the cap will stand out slightly on the top spacer.
So long as the cap sits into that spacer properly it will be ok (imo)
Welsh wheels
Welsh wheels
Lycra king
South Wales
Yep the top cap had that diameter. But I'm actually using the top cap from the original stem as it fits even better on those original spacers. Thanks for the reply.
