I've decided I might as well put a new headset on this re-build I'm doing, as I'm replacing everything else. Thankfully I seem to have a Peugeot frame that isn't awkward French sizes - the the heaset has '22.2' stamped on the top, which, from my investigation, seems to mean that I have a standard size and can replace it with a 1 1/8" headset.
First question - is this correct? The 22.2 refers to the mm size of the stem, right? And the 1 1/8" refers to the size of the frame tube? And they're mixing imperial with metric just to confuse me?
Secondly, I've fallen foul of buying the wrong stack height headset before - I fixed it that time with some creative sawing of an old cable-stopper washer, but I'd rather not do that this time (not that I have a cable-stopper washer on this bike, as it will have dual pivot brakes). How do I make sure I get the right stack height? All the ones I've looked at so far, on online shops, don't determine stack height - so I'm assuming they're only available in one size. Or do they come with a number of washers, allowing you to add/remove as suits your bike?
Thanks
Thanks
