Headset and fork bearings
TheDoctor
The TerrorVortex
Threaded or Aheadset?
If you don't know, you need to find out or get the LBS to do it.
There are two types - your Btwin has an Ahead type headset. Your SS might well have a traditional quill type arrangement.
Sheldon explains ity fully here.
http://sheldonbrown.com/headsets.html
You will need to replace like with like so if you have loose ball bearings take one down to the LBS and order some of the same.
