Doug.
- Bergerac,S.W. France
Hello.
I have bought a road bike with an unusual head set,that needs replacing.
I do not know the original head set maker.
The size is top bearing...7Hx41.8 (out side dia)by8x30.2(inside dia)x 45 degree taper on the bearing body.
The other bearing that fits in the frame bottom is 8Hx52 (o.d)8x40 (i.d) again with taper of 45 degree.
The 7h and 8h must refer to the thickness of each bearing.
I have tried on line and at bike shops and bearing suppliers,with no luck.
The bike is a modern carbon frame road bike.
Please can any one help ?
I shall be so grateful.
Thank you
Doug.
I am told that the head set is some times referred to in imperial measures as 1 and 1/8 inch by 1 and a half inch.
Thank you
Doug.
