Handlebars won't steer front wheel - still salvageable?
Alorel
Hi, folks. I bought a cheap secondhand bike as I only need it for a few months and I'm having some trouble assembling it (it's also my first time assembling a boxed bike so I have no idea what I'm doing, nor the proper terminology as you'll soon come to realise).
One of the first things I noticed when I unboxed the bike was that the bit that connects the handlebars to the rest of the bike was split at the bottom, but, as this is my first time assembling a bike, didn't give it much thought:
The problem is that when I turn the handlebars the wheel doesn't turn at all, even though I screwed the top bit as tight as it would go. When I hold the bottom bit of the tube with the bolt in it and turn the handlebars, the bit I'm holding doesn't turn, just the upper part of the tube.
Am I just being thick about something that's easily fixable or am I better off just getting a refund?
alecstilleyedye
nothing in moderation
pull the fork out of the frame to check for damage...
Diggs
The split (if you're referring to the stem wedge - see below) is fine. When you tighten the "top bit" (the quill expander bolt ) , the stem wedge should be drawn up inside the inside of the fork, this (and the angle of the join) is what holds it to the fork, assuming as @alecstilleyedye suggest the fork is intact and reaches the stem .
Have a look and make sure all is working by checking the bolt and wedge turn freely outside of the fork.
mjr
Depends how much you like the bike. Maybe it needs assembling correctly, possibly either stem or forks need replacing with ones that measure similar at key points.
A
Alorel
Wow.
  1. I was expecting to check the thread tomorrow to see one or two replies tops, but you folks respond quickly - thanks a lot!
  2. One of the first points I made was that I had no idea what I'm doing, but I didn't realise this was the extent of my cluelessness - when I bought the bike I thought the only thing I'd need is a good ol' wrench. I'll go buy a hex key so I can properly tighten the quill expander bolt and see if that does the trick. :smile:
Diggs
That's excellent @Alorel see how it goes. make sure it's secure before you go for a ride, and check it hasn't loosened after a while.
Youtube is by far the best teaching tool I have found for repairs etc. but ask if you have any questions. The people on here are very helpful.
The most important thing is to enjoy riding it!
