Handlebar Grip tape
CycleVan
London
Hi guys,
First post. Was looking for a bit of advice. I have a basic fixie bike which I'm doing up a little bit (buying parts from eBay). I've just bought some great FSA Wing Drop Handlebars to replace the standard ones my bike came with but I'm wondering if I have to wrap them in grip tape? I've never seen one without but I'm wondering if that's just a preference thing for cyclists or if you have to have them?
Also attached is a picture of my brakes. These will fit onto a my new handlebars right? Can anyone recommend a place to get covers for them?
Thanks everyone
Van
Angelfishsolo
A Velocipedian
Drop bars need different brake to straight bars so the will need changing (unless you attack them to the flats???). Bar tape is for comfort and grip. Holding onto bare metal would not be pleasant at all.
gaz
Cycle Camera TV
South Croydon
You will want specific brake leavers if you want to use that style on a drop bar. Also they my not fit due to different bar diameters. You have to fit them by the stem.
You don't have to use tape but your hands will slip if they get wet. So it's a very good idea to use tape!
Angelfishsolo
A Velocipedian
Gaz that's what I stated / asked by "on the flats" Would that actually work assuming bar diameter is ok?
gaz
Cycle Camera TV
South Croydon
It will work and lots do it provided they are the right diameter. I'm not sure how ever if you can just use the same brake leavers, I think you need shorter ones due to the different angles involved.
LosingFocus
Lost it, got it again.
That makes sense. Would look bloody awful as well IMHO :smile:
Something like cross brake levers?
http://www.simpsoncy...ake_levers_23_8
CycleVan
CycleVan
London
Wow!
Thanks for all the feedback everyone! I was thinking of attaching them to flat part and then investing in some better handles a bit further down the line. I won't need to change my whole brake right? Just the levers?
Rob3rt
Man or Moose!
Manchester
You will either need track grips or tape yes. You might also need some brake levers that fit the different diameter bar if your current ones do not, these can be cross top levers or drop levers. You wont need a new brake caliper.
Similar threads
