I can no longer get water from the cold taps in the bathroom, while water pressure downstairs appears diminished so I suspect it's only a matter of time until they're the same.
I've just been up in the loft and what appears to be the cold water tank is pretty much full. There are two outlets at the bottom - one plastic which I'm pretty confident feeds the power shower (which still works), the other copper (with what looks like a breather coming out of the top that feeds back into the top of the tank) which I assume feeds the rest of the house and where the problem lies.
The pipes are lagged and the water in the tank isn't frozen so I assume this isn't the problem. As far as I know there are no stop-cocks up there that could have been disturbed (although access is horrible so it's hard to tell); and even if there are nobody has been in the loft. I've tried "pumping" the open end of the pipe in the tank with my palm with both bathroom taps fully open, which achieves nothing.
Presumably there's only so much that can happen in the several metres of pipe between the tank and taps, but it's enough to fox me.
Any help greatly appreciated!
