 )into the gunge and turn the cranks.
 )into the gunge and turn the cranks.xroads said:Go fixed gear and bin the jockey.
jashburnham said:If it's really bad you can always unscrew the jockey wheel, take 'em out and have em a good clean, lube.
spandex said:Don't forget to replace the jockey wheels in their original positions as they are not the same, the upper wheel has a few mm of float which aids shifting. There's no need to lube the internal bearing surfaces, they are designed to run dry, although half a drop of chain lube wont do any harm.
