Not showing for me Tiny, I have no idea if you're here or not.Why has my avatar got the green online indicator showing in the top right-hand corner, when I have had that option switched off for years now? This is a privacy issue.
I can see one on mine, can't remember if I have it turned off or not.Why has my avatar got the green online indicator showing in the top right-hand corner, when I have had that option switched off for years now? This is a privacy issue.
It's the only sensible explanation.Ah, so it's showing me that I am online, in case I don't know?
Sometimes I worry for you.Thank goodness. I was seriously worried for a nanosecond.
Does it disappear when I'm offline? If so,how can I tell?Your own is visible at all times, to you.
Same way you tell if the light turns off in your fridge when you close the door.Does it disappear when I'm offline? If so,how can I tell?
You'd have to check, see if you're still here.Does it disappear when I'm offline? If so,how can I tell?
