R600
- North Scotland
Can anyone recomend a good grease for my hubs, as the grease i'm useing at the moment is working its way out within 100 miles, so looking for something that will last. this is for commuteing bike Cheers
not much help, but there's a big pot of grease in my garage I've been using that must have come from work.....
I haven't worked for the last 22 yearsbut it's still OK
I can't see why that's the fault of the grease you're using. If you think about it, bearings are submitted to pretty large loads and can pass on large shear forces to the lubricants in use. Grease, being essentially oil suspended in soap will take on the viscosity of the oil under those shear forces, and will find a way out of any gaps in the hubs. I'm thinking more that you need to see if your hubs are worn in any way, or if there is any play in them before you start going down the exotic grease route.
