feckless
- Not all that close
Does the sizing of gravel/endurance bikes differ much from race bikes all that much?
My current bike has a relatively compact road geo, with 490mm seat tube and 545mm top tube (plus 95mm stem), so fairly stretched out for the frame size.
When I look at the specs for most gravel/endurance bikes, the top tube lengths all seem very short for the frame size.
So the Look 765 has a 524mm TT in its small (490mm) frame size and the Focus Paralane 526mm in the 485 frame size. The Cervelo C3 is similar, with a 531mm TT for the 510 size frame.
All three manufacturers suggest that at 1.73m (5’8” for the old gits) I should be in the small frame size. Alas I haven’t been able to sit on any of these yet so I have no idea whether this is even remotely accurate.
Oddly, the Specialized guys were adamant I should be on a 54cm frame on the Roubaix (545mm TT). This did feel a bit tall for me when I sat on it, but not unmanageably so.
I know the “right” answer is to try all four and get properly fitted, and that I surely will do. But at this point I’m just trying to work out whether I should be reading the numbers the same way I would for a standard road frame.
Thanks
f
Thanks
f
