Scotchlovingcylist
Formerly known as Speedfreak
So I've decided I want a gravel bike, if nothing else I just think they are cool however feel they will suit my needs for a do anything type of ride and just after some advice from you lovely lot.
I had bidded on a Norco search xr steel framed rig on Ebay however this fell through but I kinda fell in love with this bike when I found it and cannot find any options to buy them in the UK at this point which is a shame.
I've since upped my budget a bit as this is a bike I'm planning on using alot and will be keeping alot of years hopefully.
After some research I'm pretty set on a Ribble gravel al, just need to decide what spec to go for.
Main questions are:
Any of you guys own or have experience of Ribble bikes.
Groupset options, I'm leaning towards the 2x grx 400 however like the idea of the single chain ring 600 or sram. The bike will be getting used for bikepacking for overnighters with tent etc hence the lean towards double chain ring up front for more gearing options, again unless anyone has any experience with either option coming out on top.
I like all the frame mount options, especially on the forks.
I'm also open to other options if anyone has any advice which is the main reason for the thread.
Budget is around 2k.
700c wheelset is a must, I have an irrational avoidance to 650b for some reason.
I'm aware Ribble do a steel frameset which I'm also considering but not interested in carbon particularly.
Hydro brakes are also a must.
Weight isn't a major factor but like the idea of something around the 10kg mark
Thanks in advance for any advice guys.
Main questions are:
