GPS logger
wisdom
Blackpool
I have a blackberry and am aware that it cannot run strava.There is an ap called gps logger availible.Would it do a similar job? Has anyone used it?
If so how is it used and can it record routes,times and speeds etc?
And advice please as i will have to keep this phone until i upgrade to a galaxy or i phone in August.:sad:
Wizz
Smurfy
Naturist Smurf
GPS Logger II works ok. You can upload the GPS data file to strava manually.
http://www.emacberry.com/gpslogger.html
wisdom
wisdom
Blackpool
Thanks yellowtim.
Would i download strava to the home pc then plug the phone to the pc?
Would the ride data transfer from phone to pc
Sorry for so many simple questions but i have never used it before.I have downloaded gps logger onto the phone now.
Smurfy
Naturist Smurf
Thanks yellowtim.
I downloaded the Blackberry interface software to a PC, then connected the phone to the PC and saved the GPS datafile to the PC, but I wouldn't have bothered doing that if I'd had a removeable memory card in the Blackberry.
You can upload the GPS data file to Strava manually just by logging onto Strava in a normal web browser, and no additional software is required for this part of the operation. I logged on using a PC, but possibly the GPS data file could be uploaded directly from your device using the Blackberry web browser, in which case you won't need a PC or the Blackberry interface software. Be aware that if you have Blackberry encryption turned on, Strava won't be able to read your GPS datafile until you copy and paste the file to an unencrypted file system.
I found that unlocking the device during or after a ride caused me to inadvertently exit the GPS Logger II app, if this happens just select 'Confirm Exit of GPSLogger II' in the General Settings Options. I have my minimum speed for logging set to 3mph, but I haven't really tested this to see if it's appropriate. I use 1 second logging for Strava segments, and 5 second logging when I'm not bothered about Strava.
To be honest, although I've worked out how to do it, I haven't bothered with Strava much. I have uploaded one very short segment ridden on my fixed wheel bike, on which I scored second place. Mostly I just log longer rides to create a record of where I've been.
subaqua
What’s the point
Leytonstone
or use endomondo and export the gpx file from the website. have even succeeded in transfering the gpx file from the website onto wifeys garmin in car sat nav and getting her to follow the route in a car
wisdom
wisdom
Blackpool
Its all a bit beyond me what you guys have done.So it looks like i will have to miss out until later in the year when i can change my phone.Thanks for the replys though.
subaqua
What’s the point
Leytonstone
download endomondo for blackberry in the app world on the blackberry. install on blackberry ( it does this for you follow the prompts) create an account, start endomondo on the blackberry go for a ride stoip endomondo when you have finished the ride. go to endomondo .com , log in and see the route under workouts.
wisdom
wisdom
Blackpool
Thanks subaqua.
I have just done that it looks a bit easier than the gps logger.Can the endomondo be uploaded to strava?Thanks again all.Wizz
subaqua
What’s the point
Leytonstone
Thanks subaqua.
on the website open one of your workouts and click more options just above the map, click on export then click on export file type that strava will open . I don't use strava so dunno which type of file it opens or how to import it into strava
PpPete
Chandler's Ford
My Android phone can do Strava but I don't bother as it eats battery when the GPS is turned on. You can certainly upload a regular .GPX file to Strava. (It's what I do from my Garmin)
wisdom
wisdom
Blackpool
Please could you tell me what a gpx file is?And would it be straight foreward if i plugged the blackberry into the pc?
subaqua
What’s the point
Leytonstone
the gpx isn't stored on the blackberry . I thought i could do that . you need to log into your account on the webpage .
