Good clean, Found damage
Liamjc90
Aberdeen
So i finally gave the bike after 3 months of daily riding. Yes i know long over due but it didn't seem that bad. Photo below is a after photo forgot to take before.
But then i found this on the cassette, could it cause any problems or will it need changed?
Any help or advice appreciated.
Norm
It could cause issues but, tbh, I'd be as concerned at the state of the chain as well. You might think that it didn't look that bad before but, as you've found, a clean is about checking the bike over as much as anything.
deptfordmarmoset
Full time tea drinker
Armonmy Way
The teeth on the cassette look ok to me, well, apart from the 2 missing ones, that is, so if it's not slipping the cassette probably just needs a good clean and a regular dose of lube. There's a good chance that the chain was involved in whatever sheared off those 2 missing teeth so I'd give the chain a thorough inspection for damage after giving it an equally thorough clean.
Liamjc90
Liamjc90
Aberdeen
No dont think its a hyperglide chain, the bike wasn't expensive and i'm planning to upgrade after winter. I was hoping that i could just leave it and it would be fine. I haven't noticed any damage eles where apart from the rust the chain looks fine and the chainrings still look good. so i guess my real question will it survive the winter?
Liamjc90
Liamjc90
Aberdeen
Good point. I may just price up the items and take the plunge, so on a related note would it be difficult to change had not real experience with bike? Im a mechanical fitter by trade so usually quite good with this sort of thing.
Liamjc90
Liamjc90
Aberdeen
I have been riding it. im not sure when it happened exactly, it was some time in the last month. I haven't noticed any slipping and i do use that cog for climbing some smaller hills. Im looking at around £40 for cassette, chain and tools.
Overconfidentii Vulgaris
I'd join with everyone else saying a new chain and cassette. I'd also (cheekily) suggest that slightly more frequent oiling of the chain would be beneficial. My current chain (same type as yours) on the knockabout bike is almost a year old now and has been ridden through mud, rain and road salt but it doesn't look nearly as bad as that.
It can be done for slightly less than £40:
Chain
Cassette
Chain Whip
Cassette Tool
Total cost £32.58 (at the time of writing) with free delivery.
MrJamie
Oaf on a Bike
In addition to Phil's most excellent links, if you want a bit of a ghetto fix rather than buying a chainwhip you can hold the old cassette to stop it spinning with a pipe wrench, as when putting on the new cassette and lockring you dont need a chainwhip anyway. :smile:
My last chain/cassette replacement +chain tool cost about £22 and i splashed out on a £10 chain ;)
