Hi there,
I'm currently using a 56cm (horizontal) 2013 Scott Cr1 Comp, but as it always felt stretched I swapped the 100mm stem for a 90mm one. Using a 6 degree stem the drop from the saddle to the bars feel just right.
Now, I'm considering buying a 56cm Cube Agree GTC.
This has a shorter horizontal head tube at 54.5cm (so it ticks that box), but a much shorter headtube at 145mm (vs. 176mmo on the Scott).
For what it's worth, the stack on the Cube is 541mm vs 584mm on the Scott.
I really like the bike and top-tube wise it's fine, but I wanted your view as to whether that would be too slammed on the stem given the difference in headtube length? I'm buying the bike unseen (yes, I know...)
I could go for a 10degree strem I guess and turn the bars ever so slightly as well.
Any thoughts?
Thanks
Any thoughts?
Thanks
