Glue for carbon frame
Sambu
E.yorks
Got one of those imobilize things, its a little chip which im supposed to glue inside the frame. What i need to know is, what glue is safe on carbon? i dont want to go melting my frame.
Cheers
Use epoxy/araldite - it doesn't react with anything.
Sambu
Sambu
E.yorks
Yea i assumed they would provide something. il go for the epoxy approach, out of interest where did you put yours? i was thinking in the bottle cage bolt hole in the seat tube.
Judderz
Cheers
Can you tell us more about the immobilize thing...I might be interested in that...cheers
Here
Comes in 2 flavours. I went for the 'split frame' option - the tag just glues somewhere inside your frame (as inaccessible as possible) Other option (I think) is something like a star-fangled nut that you just push down a frame tube.
Its the only way I can think of of marking a carbon frame. Stamping a postcode into a carbon frame sounds an extrodinarily bad idea to me.
