Glasses And Rain
mgarl10024
Bristol
Hi,
I unfortunately got caught in quite a heavy rain shower over Bristol this evening on my commute home.
I don't mind getting wet, but the worst part for me is that my glasses soon get covered in rain and I can't see where I'm going (bit of a safety issue!).
What do other people do?
I've contemplated a few ideas...
- I've got a helmet with a visor to keep some of the water off.
- I don't like the idea of contacts.
- I've considered some sort of 'goggles' that I could wear over the glasses, but they would need to be lightish as I'd have to take them everywhere to ensure that I had them when needed, and as my gf pointed out "wouldn't they just get coated with water like the glasses do". hm.
- This post
- Some sort of comical wiper assembly.
Must be a common complaint.
Thanks,
MG
Midlands
I find a quick wipe with a finger works on the outside - visor prevents most getting to the inside
Its cycling in fog I find worst where they mist on both sides
Fab Foodie
Kirton, Devon.
I find an 'old-fashioned' cycle-cap worn under my helmet works much better than the helmet visor at keeping rain off my glasses. Prendas sell a wide range.
Matthames
East Sussex
Depends on how bad your eyesight is. Usually I look over my glasses in the rain as I am able to see well enough to negotiate traffic, but for some people this may not be an option. Another option is to get water repellent to spray on your glasses, something like Salclear which is used on motorcycle visors where rain droplets are an even bigger problem.
Brandane
Miles cannot be done unless moving!
Costa Clyde.
+1.... Although I haven't used Salclear, I have used a Nikwax product on my motorcycle visor which does the same job. It is designed for plastic though, as an alternative to Rain-X (for car windscreens) which people were using on their plastic visors but it makes them brittle, allegedly! Come to think of it, you could try treating your glasses with Rain-X. Makes the rain form into droplets that run straight off the glass.
Helmet with visor is probably the best. For those who don't wear a helmet, forget the stigma, wear a baseball or similar peaked cap. What I (helmetless) do, is wear a brimmed hat, which works well, but looks quirky (as if it mattered to me!) and sometimes blows off in the wind.
The helmet peak works best for me on the hybrid, I find it less of a problem on the road bike; even though I'm a victim of fashion :blush: and tend not to wear a peak on a road bike. I've just got a Rapha cycling cap (free :smile: ) its too hot just now but I'll probably wear that when I'm on the road bike.
jay clock
Massive member
Hampshire UK
firstly give lenses a try. Daily disposables are pain free. Second (pricier) option which I went for is laser surgery. Has transformed my life. Honest.
palinurus
Velo, boulot, dodo
Watford
Another vote for the cycling cap solution. Cheap, effective and versatile.
C
chillyuk
I take mine off.
I can see well enough to see traffic, pot holes or street ironwork even though I probably struggle to read numberplates from more than about 10 metres.
Funny enough as I get used to not wearing my glasses my eyesight seems to improve as the ride progresses.
wafflycat
As a speccy-type I learnt the hard way about specs/rain/cycling. The bottom line is that in heavy rain, the best solution to the problem is contacts. I've tried all sorts of ways of trying to keep the specs free of water, all sorts of peaked cap/lid combinations, but contacts have been the best solution when the rain is heavy.
Being short-sighted, I need to wear specs for distance vision, but not for close work or reading.
Think about giving contacts a go. I got some 'soft' lenses many years ago. I too *loathe* anything being put in my eyes, but found that by the time a month had elapsed, putting in and taking out lenses became second nature and no hassle at all. I now use daily disposables when I'm using contacts. Saying that, I still wear my specs most of the time, keeping the lens wearing for 'special occasions' mostly and for cycling when the rain is *bad*.
John the Monkey
Frivolous Cyclist
Crewe
contacts aren't as bad as you think they will be (soft dailies aren't, at least).
I wear glasses in the rain - having a good wipe on your mitts helps (spesh's Microsuede stuff is very good, ime), as does a cycling cap (the peak is better than a helmet visor). If it's really heavy, I stop & wait for it to ease up.
Banjo
Fuelled with Jelly Babies
South Wales
I use the soft cloth back of my cycling gloves to wipe off the worst.
Has anyone actually tried rain X or similar on cycling glasses? I wouldnt have thought cycling would be fast enough for the wind to blow the droplets away.
