Giant TCR/defy owners seat issues
Nearly there
Cumbria
My seat keeps coming loose what am I doing wrong?I get it level etc tighten rear bolt to correct torque however the tightening thing under the seat keeps slackening off after a while its frustrating.
Cuchilo
Prize winning member X2
London
I know it is ! I tightened mine until it wouldn't go any more .
John the Monkey
Frivolous Cyclist
Crewe
I had the same on the SCR2.0 seatpost - I shimmed it with a bit of old coke can (other beverages would work too). A single thickness of can between the ridged clamping bit and the clamping surface.
Also, grease the bolt (if you haven't already) that should allow it to be nipped up a bit tighter.
Nearly there
Nearly there
Cumbria
Its that round thing that comes loose
Cuchilo
London
You need to nip it up tight once the saddle is on . Not easy if you don't have a hole in the saddle to get to the top of it .
