Giant PR2 front wheel bearing
Galali
Regular
Hi Guys.
I’m needing to renew my front wheel bearings. How foes this come apart? Any advice greatly appreciated
SydZ
Planet Earth
Looks like the end caps come off then, whilst protecting the axle, tap one end to knock out the opposite bearing. Then, from the side with the noe removed bearing, drift out the one on the opposite side.
This is a different hub but the principle looks the same.
View: https://youtu.be/5jeuYRVqc-4
shaftdrive
If these end caps just pull off then mine are really tight.Is there a way to remove them without marking or damaging them?
