Deleted member 35268
Giant Defy mudguards have a tendency to break around the rivet points, usually the rear guard, with rivets working loose over time then shearing through the plastic mudguard. The other failure is usually the mudguard itself snapping near the rivet joints. See circled area on rear.
I managed to save my self £20 for a new set by drilling two new rivet holes in a slightly shortened mudguard, and re-attached to the metal mount using small bolts. I am expecting the bolt to want to work loose over time, so I will keep an eye on it.
