Joe24
- Nottingham
The front brake on the Giant is stuck in the forks, and i need to get it off to put a new one on.
The brake keeps sticking on, and ive had penetrating sprey put on it, stuff that was stronger then WD40, ive taken the spring off and then put more tension on(do this when the back one does it and it works) changed the cable, inner and outer. The thing still sticks on.
When the back one kept sticking, i took the brake off, loosened the middle bolt slightly and wiped everything on the brake, put some more spring tension on and the brake was fine.
Not working with the front one, so im going to put a new one on.
How can i get it off? My ideas are:
Cut as much of the brake off as i can so i can wack the bolt out.
Drill out the brake nut bit at the back(sunk into the forks, if you get what i mean) with the big pillar drills and clamp the forks.
I cannot turn the bolt, its had longer allen keys in(took it to someone in the club) and he couldnt get it out.
So, its stuck. How should i get it out?
Cheers
Cheers
