The Hat
Hi all,
Am selling my Geoff Smith Pennine tourer, as i just dont use it. It is in superb condition and has only had about 50 miles through it. Ordered and purchased from Geoff himself who is my lbs. Top quality Reynolds 725 tubing with a unique paint scheme which i chose which Geoff tells me is the only one he has done like it. These normally come as standard with a Sora groupset but i upgraded to 105 which as a tourer is a triple, 50,39,30 Upgraded Shimano brakes and cafe brake levers added. It is a simple job to change the chainset if more low end gearing is needed.
This is a top quality tourer handbuilt by the man himself. Built to last and take you hundreds if not thousands of miles at a time. Cost me £1400 just over 12 months ago. It is exactly the same frame as a Paul Hewitt Cheviot SE, literally .
yours for £800
Size wise, I'm 5'7" with a 29" inside leg and it's a perfect fit for me with about 1" left from my gentlemans area to top tube. This is a nice relaxed bike made for touring long distances in comfort.
Measurements,
Top tube is 50cm
Centre crank to top tube 45cm
Ground to top tube 73cm
Stem height from ground 89cm with a further 3cm up adjustment of needed.
100mm stem
Exactly same geometry as a small Paul Hewitt Cheviot SE
yours for £800
Measurements,
Top tube is 50cm
100mm stem
