I am purchasing a Genesis Equilibrium 20 (2016 model) frameset. I want both 28mm tires and mudguards, but wasn't sure this was possible. Evans Cycles told me this: "Genesis say that it can take 25mm tyre with mudguards and 28mm without. I'd be pretty confident that you could go to 28mm with the correct set of mudguards but nothing exceeding that." They then said that 28mm tires would probably work with SKS Mudguards Narrow Road. Does anyone have experience of this setup (i.e. with a 28mm tire and mudguards)? If so, does it work well and what tires do you use?Ah but it's 725 steel, not alu, class costsYes those are 25mm michelins and full sks chromoplastics
Many thanks.
