Gears again
My front set has 3 cogs - rear has 8
at the rear, if gear one is the one I need when im desperate to get up a hill - the following is happening...
on the way down through the gears (towards one) - it always wants to skip gear 2
on the way up through the gears it always wants to skip gear 5
this has started happening in the last 20 miles
Any ideas, i'm trying micro adjustments with the 2 small screws on the rear deralier?
PatrickPending
Leicester
your rear mech needs adjusting, probably not the two screws tho - but they probably need tweaking now - its cable tension that needs tweaking, many articles on youtube such as
http://www.youtube.c...h?v=D0Xt_QCHD1U
the two screws on the rear mech adjust how far it will swing - set so that the mech wont throw the chain off the cogs ie beyond 1st or 8th - there's also a b-screw which does something else - though unless its a new mech it'll probably not need aadjusting as it should have been set up correctly when it was purchased - your problem is due to cable tension though.........
have fun!
