Hi Guys,
Could i grab some advice on gear shifting?
1st time rider since the summer last year and bought my first bike being a Bianchi intenso. It has a campagnolo centaur gear set on it and ive used the bike a fair bit and some of the gears became a bit slow to change, always around 8,9,10/ I have had the gears indexed and it feels much better in that respect. Id also had a few problems when shifting from the small to large chain when in the larger rear cogs and they said it looked like the front derailleur was set to low.
Ive since took the bike out for a short run and its still struggling to move to the large chainwheel when in the larger rear cogs. It has to be at least the 4th gear before it will grab the large chainwheel.
So question is, being a novice should i be avoiding moving to the large chainwheel from the large cogs at the rear or does it need more adjustment?
Thanks for any help
Thanks for any help
by the way - have the cables been changed at all? If it's a 10 speed Intenso I'm guessing you didn't buy it new?
