Hi
I have a new problem with my bike. Feel like I'm cursed
This time it is front left Shimano Claris shifter not functioning for the front mech.
Prior to the failure, the shifting was not smooth anymore, I think not long ago I posted how I had to push the lever with 2 hands in order to move the front mech on to the big ring. I sprayed some lubricant and seemed to ease the problem.
But now recently its no longer functioning at all.
Usually, I just retensioned the cable and use the barrel adjuster which would usually fix the problem.
I will attach some files for you to see better.
Things to note:
The front mech moves fine by hand.
When push both levers at the same time the small gets stuck as seen in the photo and only gets back into position if I do it manually, but when I only push the small lever on its own then it comes back to its natural position.
The barrel adjuster seems worn a little but I don't think that is the main issue.
Please see the photos and advise what this can be.
I hope I don't have to buy a new shifter.
Thanks.
Things to note:
Thanks.
