Gear Ratios
Enw.nigel
Cardiff
I,m looking at bikes again to replace my Focus Cayo 105 that was stolen last week and I am back to this question over compact v triple. I don't want this to turn into a debate over which is better because I can see advantages to both systems so it will be up to me to make up my mind. I am after some answers to help me make that decision. There is more choice of bike if i change to a compact.
Until last week i was riding a Cayo triple of 50/39/30 with a 12-27 cassette. Now my riding style on hills meant that I rarely used the 30 chainring as I would try to keep on the 39 chainring and let my legs do the work. However there are some hills where I have no choice but to drop down to the 30 chainring so it is always there as a fallback.
Now I have been trying to compare the triple to a compact running 50/34 with a 11-28 cassette to see if I get a similar low gear and come across a gear ratio calculator on the web and it gives me this:-
Triple Chainring 30 Cassette 27 ratio 1.1
Compact Chainring 34 Cassette 28 ratio 1.2
For high gears I get this:-
Triple Chainring 50 Cassette 12 ratio 4.2
Compact Chainring 50 cassette 11 ratio 4.6
Does this mean that the ratios of 1.1 and 1.2 for the low gears are so close togethe that, even though the compact ratio is higher by 0.1, I would not really notice it being harder to climb.
At the other end of the scale with the higher gears the ratios are 4.2 and 4.6 so there is a marked difference between these giving you a possible higher top speed.
I appreciate that with a triple there is a lot of repetition of gears between the high and low gears and that if I do change to a compact I will have to alter my riding style and relearn the gears. More double shifting and most probably my average cadence improving because of my stubborness not to use the granny ring.
Another factor I have to consider is my age (62) hence the question of the lower gearing being similar on the compact and triple in my example above.
Can anyone help? Am I on the right track with my comparison or am I comparing the gears from the wrong angle?
Sorry it's so long winded but I don't want to change to a compact only to find the lower gears that very much harder.
BSRU
A Human Being
Swindon
Why not use Sheldons gear calculator
http://www.sheldonbrown.com/gears/
It tells you the distance in metres developed( or in inches) for each gear ratio.
Enw.nigel
Enw.nigel
Cardiff
Thanks for that BSRU
This is the information I get for the low gears.
34:28 = 2.5
30:27 = 2.2
If this is in metres, as you say, is this metres travelled for one revolution of the crank?
If so the triple setup travels 2.2m and the compact 2.5m? A difference of 0.3 or 300mm doesn't appear much of a distance so there would be little difference in effort in hill climbing between the two.
Or have I got this line of reasoning wrong?
BSRU
A Human Being
Swindon
34:28 = 2.5
30:27 = 2.2
Yes, "Development is the distance the bicycle travels for one crank revolution".
My hybrid has the lowest at 2.2m and the next cog is 2.5, their does not feel like that much difference.
Enw.nigel
Enw.nigel
Cardiff
BSRU Thanks for that. Ever thought of taking up teaching?
I will look into the gear ratios a bit more using Sheldon.
For what it is worth, I was a confirmed user of triples, and moved to a compact on my latest bike. I have fallen in love with it as a method of transmission. I seem to get more usable, not to mention easily accessible, gears from a 2 x 10 than I ever got from a 3 x 9.
