MacB
- Farnborough, Hampshire
Ok, I joined another thread recently, received some great info, and have also read all I can find on this subject, though not understood all of it
. So I've been analysing my current gear ratio and considering future options(already sizing up my next bike and not even finished tinkering with current one
Current bike - 30/42/52 & 12-26 9 speed, 175mm cranks, this gives me a range, in inches, from 31.4 to 117.7, totalling 27 gears. Now I discount 4 of these gears, the 52-26&23 and the 30-12&13, removing 54.3, 61.4, 62.7 & 67.9 inches from the range. This reduces me to 23 gears, of these there are 2 that are both 54.3 inches and another 2 where the gap is only 0.2 inches. This reduces my effective range of gears to 21, across this range the gaps between gears go from 0.9 to 9 inches. If I then ignore the top 2 gears(hardest ones) which, at 109 and 118 inches, I'm unlikely to get to, then this reduces again to 19 useable gears. Range now 31.4 to 100.9 inches and gaps variance from 0.9 to 7.3 inches. A smooth progression would be increments of 3.66 inches.
Right, that's the boring bumph out of the way and would appreciate it if someone, maybe Rando, could verify if the above is a correct assessment. If it is then I get to the conclusion that I actually have nothing like 27 gears. If I smooth out the progression and only look at changes where the impact is greater than 2 inches(they're all either <2 or >3), then I get a final number of 13 gears.
Question, am I just stating the blindingly obvious by feeling that all of my extra teeth and cogs do nothing but give me more to maintain and more to go wrong? At least I think I now understand why my shifters allow me to move multiple cogs at a time
. Messing about with SB's calculator I seem to be able to meet all my needs with a double 34/42 and a rear 7 speed 13-30 or 12-32, assuming all 14 gears would be available without the chain rubbing on the derailer.
Are 7 speed cassettes going to be discontinued, do I need to devote my future musings to 10 speed and upwards? Any thoughts on all this appreciated, if you're not asleep already
).Current bike - 30/42/52 & 12-26 9 speed, 175mm cranks, this gives me a range, in inches, from 31.4 to 117.7, totalling 27 gears. Now I discount 4 of these gears, the 52-26&23 and the 30-12&13, removing 54.3, 61.4, 62.7 & 67.9 inches from the range. This reduces me to 23 gears, of these there are 2 that are both 54.3 inches and another 2 where the gap is only 0.2 inches. This reduces my effective range of gears to 21, across this range the gaps between gears go from 0.9 to 9 inches. If I then ignore the top 2 gears(hardest ones) which, at 109 and 118 inches, I'm unlikely to get to, then this reduces again to 19 useable gears. Range now 31.4 to 100.9 inches and gaps variance from 0.9 to 7.3 inches. A smooth progression would be increments of 3.66 inches.
. Messing about with SB's calculator I seem to be able to meet all my needs with a double 34/42 and a rear 7 speed 13-30 or 12-32, assuming all 14 gears would be available without the chain rubbing on the derailer.Are 7 speed cassettes going to be discontinued, do I need to devote my future musings to 10 speed and upwards? Any thoughts on all this appreciated, if you're not asleep already
Looked at Thorn as well, I can see an expensive new bike on the horizon, the temptation of the Rohloff hub is becoming irresistable......must find some bad reviews.......
I just feel a bit of a fool from starting out believing I really had 27 gears to the realisation that it's a lot of smoke and mirrors
) is now a triple for exactly that reason.
