simmi
- Auckley, Doncaster
I am a bit of a tinkerer and am at the moment tinkering with my cassette ratios to get the optimum set up for me. (43 just starting out cycling with a average speed between 15 and 16mph and lets face it am never going to get Wiggins quaking in his boots)
With a bit of maths I have worked out that with a cadence of 90 and a wheel diameter of 675mm with a ratio of 1 : 1 I will be moving at 7.12mph so to translate to my current set up in my highest gear 52/11 I would be moving at 33.7mph and my lowest 39/28 would be 9.9mph.
My thinking is why on earth do most cassettes start off with 11 or 12 teeth, even with 14 I would be doing 26.4 mph.
On the flat I can keep to about 18-20mph for some time and obviously down hills can get higher speeds but to be honest spend more time coasting than pedalling.
I am going to change my set up from 11/12/13/15/17/19/21/24/28 to 14/15/16/17/19/21/23/25/28.
I am sure pro's and top club cyclists need the 11 and 12 teeth cogs but not sure why the rest of us would have them.
With a triple or compact chainset I can see this is a different matter, but with you standardish 39/52 double how often would 75% of cyclists use them?
Perhaps I am getting a little over involved for my level or ability but really just want to get the maximum from the effort I put in.
Any thoughts on my musings would be welcome.
