Gear Ratio
Alex1982
Scotland
Guys
I have a Cervelo S2 and looking at giving myself a more relaxed gear ratio for long hilly climbs,
I am currently running 11-28 cassette and a 52/36 chainset
I am understand that if I was to go to a 30 or 32 tooth cassette I would need a longer chain and larger rear derailleur so I am wondering is it possible to chain the chains and take links out the chain in order to provide me easier gears for climbing.
If this is correct what size would be good for trying?
I was thinking
https://www.sigmasport.co.uk/item/Rotor/Q-Ring-Inner-Chainring-110BCD/XPT
https://www.sigmasport.co.uk/item/Rotor/No-Q-Ring-Outer-Chainring-110BCD/11AY
50/34
Would that be a good climbing ratio with the 11-28 cassette
MontyVeda
i switched from an 11-28 to a 12-32 and didn't need to extend the chain or fit a longer dérailleur. Just give it a try. It certainly made my climbs a lot more relaxed.
(edit) ..depending how long your current cassette has been on for, you might want to replace the chain anyway.
Spiderweb
Not So Special One
North Yorkshire
In my experience you could use a 30t cassette with your existing rear mech ( I presume it's a short cage) anymore and you would need a longer cage. You would probably get away with using the same length chain, maybe fit a slightly longer chain when it next needs replacing.
A
Alex1982
Scotland
Thanks
So if i did both I would still need the larger derailleur and possible new cabling for the additional length, longer chain.
S-Express
If it suits your level of fitness, then yes.
A
Alex1982
Scotland
Might see if I can get a lend of a different ratio next club ride.
Is a bike speed relevant to the number of cogs you have in the cassette? i.e. if there are 11 you have an 11 speed bike?
A
Alex1982
Scotland
Yeah I think that is what I am looking at doing after reading and watching videos on climbing
Just not sure if the items I have found are compatible with my bike so waiting for a email back
Going to get these and get my LBS to fit with new chain and cabling.
Will this be ok?
Rotor Q-Ring BCD 110 Outer Chainring
Colour: Black
Size: 50T x 110 x 5
Quantity: Remove
£108.00
£100.00
YOU SAVE £8.00
Rotor Q-Ring BCD 110 Inner Chainring
Colour: Black
Size: 34T x 110 x 5
Quantity: Remove
£54.00
£50.00
YOU SAVE £4.00
Shimano CS-5800 105 11 Speed Cassette
Colour: Silver
Quantity: Remove
£54.99
£46.74
YOU SAVE £8.25
Shimano RD-5800 105 11 Speed Rear Derailleur
Colour: Black
Quantity: Remove
£5
