0lonerider
- tyneside
The lad who's owns the bike said he had fiddled with the adjusting screws before i had a look! Iv tryed to reset them slightly but nothing will make them change upto 1st 2nd
Or 3rd???
I checked the shifter and it worked ok
So does the shifter work fine, or not? Unbolt the cable from the derailleur. You've said the RD moves far enough to reach the largest sprocket (of 7) and when released should sit in line with the smallest (adjust limit screw till it does). So the problem's (as @boydj says) seems to be in the shifter. Give it a good squirt of WD40 or similar. With no cable tension can you get 6 clicks, up and down? You need to. What do you mean, it's "very tight" going up? Holding the cable in your fingers, when you click the shifter, does the cable move as you'd expect? Perhaps an image of the shifter might help, so we know what type it is.The rear derailleur moves fine by hand but the shifter is very tight when trying to shift up
I suggest that's just an effect of the light on the second image: The other two images suggest the hanger is fine.The back of the gear hanger looks like it has had something snapped off it,
For the avoidance of doubt, we have images of the rear derailleur in your OP: I'm suggesting an image of the shifter (ie the right one on the bars) as the problem is either there or (I'm postulating pending answers to my other questions) a chain that's somehow been fitted too short.there's pics of the shifter above
