andyfraser
- Bristol
Hi,
I've been having a little difficulty setting up the Sora front derailleur on my new Felt F95. I can get it so 34x25 is ok but 34x11 will rub. When I tension the cable 34x11 is ok but 34x25 will rub. 50x11 is ok and I haven't bothered with 50x25 feeling that that shouldn't work anyway.
So the question is, for a compact chainset am I supposed to have access to all rear sprockets on the small chainring or should I be shifting up before I reach the smallest rear sprocket? The front derailleur shifts perfectly fine otherwise.
On my Kona I have full access to all 9 sprockets on the middle (38) chainring but the cage is a different shape. I wouldn't dream of going to the extremes on the 30 or 48 chainrings so I may have picked up a bad habit of staying on one chainring here.
