Gear cable clamps (vintage)
rorytymon
Regular
Hi there I'm new to cycling and decided to buy an old beat up bike not long ago and have fun restoring it. I'm in the process of removing all the parts and have found the gear cable clamps (outside mounted) have two cables per clamp - pictures attached.
Does anyone know where I can get hold of some replacements for these as I'll have to break one of them due to it not having a screw.
Many thanks, Rory.
P.S. What colour should I paint the frame, grip tape colours shown for judgment :smile:
midlife
Welcome :smile:. Not sure what you mean? The whole of the inner cable / outer needs ditching and moving over to bare cables, not sure why the previous owner did that.
As for colour that's a personal choice :smile:
R
rorytymon
Regular
Thanks for the reply. The gear cables are outer ones I was asking about the clamps that hold them down, not sure of they have a proper name or not
carpenter
suffolk
Hi,
Welcome to the forum.
I am not sure why the cable outers (and they look quite expensive ones) run the whole length of the tube from the levers - can you take a picture of the bottom bracket end of the fame looking from above (like these):
526876
526877
If you have "braze on" cable guides (first image) really easy and no need for cable outer all the way down from the levers, just bare wire.
If there are no cable guides down there then you will need a "bolt on" cable guide (second image), again really easy and you can get the guides like these:
https://www.ebay.co.uk/itm/SHIMANO-...970960?hash=item2aca701ad0:g:AQYAAMXQq8BQ4fSE
Any more questions please just ask - happy to help :smile:
on the colour, whatever turns you on (sorry if you chose the handlebar tape, but I don't like multi colour - I'm old and conventional, brown, black or white).
On type of paint, I would suggest enamel if bike is valuable/nice lugs or powder coat if lugs are simple - some amazing effects/finishes available in powder coat now (on fancy lugs powder coating can obscure the detail/fine lines).
edit: by the way, first image is powder coat, second stove enamel.
R
rorytymon
Regular
Thanks for the reply. I am assuming my bike is like the second image as it has no metal runners attached to the bike itself (its dark right now I can add some pictures tomorrow if needed). Ill buy one of those cable guides which to have shown. I have another question, how do I know when you have the cable in the protective tubing and when to have it running bare like the top image?
Thanks, Rory.
Hi,
carpenter
suffolk
Morning Rory,
Your bike frame seems strange to me, does it have no braze ons for derailleur gear cables (others on here would have more experience, but was it originally made for Sturmley Archer gears?). Anyway, if there are no braze ons you will also need one of these:
526926
526927
https://www.ebay.co.uk/itm/GENUINE-...995779?hash=item2f2ed247c3:g:AeYAAMXQQJBQ9GSd
I tend to use as little outer casing as possible on straight runs (reduce friction), only needed to smoothly guide inner cable around curves/bends:
526928
526929
Regards. Guy.
Hi and :welcome:
There is also another means of guiding and routing the cables underneath the bottom bracket by using a plastic guide fitted to the bottom bracket .
I just zoomed in on one of your pictures and that is how your cables run .
R
rorytymon
Regular
Morning Rory,
Regards. Guy.
Thanks Guy, they are braze ons by the looks of things, ive just taken everything off and I think the previous owner has essentially cable tied everything on. Ive ordered some of the fittings, thanks a lot for your help!
