garmin and strava messing up
young Ed
so today my garmin has told strava and garmin connect that i went into the middle of a field and out again and i didn't
also strava maintains my max speed was 40 something mi/h rather than the true 27 something mi/h
what is happening?!
Cheers Ed
Stu Smith
Lancashire
Went on the Turbo Trainer today. My Garmin told Garmin Connect that my average speed was 17.4 mph which sounds about right.
But it also told Garmin Connect that my max was 47 mph:laugh: and that was at 80 mins in to a 90min session somehow I don't think so...
young Ed
young Ed
you are bloody good my friend achieving 47mph during the cool down of a ride! :biggrin:
Cheers Ed
young Ed
young Ed
what garmin do you have and how do you calculate speed on a turbo is it done with a cadence sensor?
Cheers Ed
ColinJ
Puzzle game procrastinator!
Are you sure Strava isn't working in km/hr?
PS How come your MCL target is only 1,000 miles for the year when you will be doing getting on for that just on your LEJOG, and I think you said elsewhere that you were following that with a JOGLE?
Sounds like you had a satellite blip and lost one of them for a few moments and it was estimating your position from the remaining ones until a moment (second) or two later it found the other/another satellite and corrected itself.
If you were on a road, there is a website that can correct it for you http://strava-tools.raceshape.com/snap/ though I will point out I have not tried the site myself
young Ed
young Ed
not km as average speed is correct in mph but i did convert 27 miles(my real max speed) into km and it was very close to what strava said for miles
and the end to end (still not sure which way but probably lejog) is next year and as i am cycling to the start point and home from the finish point (about 2000 miles) i will set MCL target for next year at about 3.5 or 4k
sounds a feasible explanation not too bothered about correcting it just confused! still doesn't explain the speed issue that both me and @Stu Smith had :headshake:
Cheers Ed
Cheers Ed
your max speed will have been distorted by you suddenly switched from a road to the field and back (as far as it is concerned) and could be accurate for the signal loss. It will also have added a few metres or more to your distance. If you run it through the snap to road thingy it will probably iron out the max speed issue. I have had them well above +400kph in the past because of satellite issues...
young Ed
young Ed
fair enough might give it a go then in any case i think i think i was going rather fast there :biggrin: isn't wind resistance a slight issue at 400kph? don't you break your neck?
Cheers Ed
Nearly there
Cumbria
I went for a walk around buttermere lake on Sunday my partner used a Samsung galaxy 3 and I used my Garmin both read different miles mine at 4.7 and hers 5.1 upon checking our maps on strava my Garmin cut corners through fields where as the phone app showed the true path.
