goo_mason
Champion barbed-wire hurdler
- Leith, Edinburgh
My rear brake has been a bit dodgy lately (feels stiff and grind-y when I'm pulling on the lever), so I loosened it off to slide the cable-covers out of the way and lube the dirty, dry cable. That was all fine, until I realised that the cable cap was no longer on the end of the cable.
It was still in the barrel-adjuster, and appears to have fused with it. No amount of teasing with a tiny screwdriver blade / WD40 application / attempting to grip and pull with pliers worked.
I may try to get hold of some needle-nose pliers and try to get more purchase on it - but should I need to replace the fancy barrel-adjuster on the rear brake of my 2008 Giant SCR2, where do I go ? I've been googling without much success.
