goo_mason
Champion barbed-wire hurdler
 - Leith, Edinburgh
Bought a set of these two months ago for use as my 'summer' wheels, and finally fitted them last night as the weather's finally looking good for the whole week.
An hour after I'd finished, the back tyre suddenly went down with a mighty rush of air. Checked the tyre and the rim around the area where the tube was holed for anything sharp but couldn't feel anything. So, off came the wheel and I put on a brand new Schwalbe tube.
I pumped it up again but this time, just as it was reaching the ideal pressure, it burst with an almighty bang which blew the tyre off the rim! The hole was in a different place, so I checked the rim and tyre again for sharps - nothing. I suspect I may have pinched the tube slightly under the bead, though I always ensure that I check for this and have never had a tube explode on me in 7 years of fixing flats. So - I patched both tubes and put the original back in again, only for it to let go with another big rush of air 5 minutes later. I suspect the patch may have lifted, but it was so late that I couldn't be bothered taking the wheel off and getting the tube out yet again.
Seriously miffed, as I had to bus it in this morning on a beautiful day. I'll pop into the LBS on the way home tonight to buy a couple of new inner-tubes and perhaps some new rim-tape to replace the stuff that came on the wheels. I'll also give the wheel rims a damn good check tonight for any sharp edges as I've never this kind of problem with the previous 4 wheelsets.
Anyone got any other advice for potential causes that I should look out for?
