oldgreyandslow
- Farnborough
Further to my rear wheel bearing noise post, I got some new bearings, 6001 2RS, type. I removed one of the rubber seals from each bearing to fit on the inside and fitted them in, all straight and perfect but....................................
I forgot to fit the sleeve/tube that fits in the middle between the two bearings! Oops
I guess this means I'm going to have to take one out again and fit it?
Unfortunately getting the bearings out was a royal pain in the backside last time so I expect I'll bugger one up getting it out becauise you can't get to the outer ring of the bearing only the inner and too much pressure here will no doubt trash it.
Lesson learned.
Lesson learned.
