Howdy!
Can anyone help out with a problem I've encountered with a (self installed) new headset? Story is...
My old headset (FSA Orbit IS) was getting loose, so nipped it up only to find it was indexed. No probs I thought - it's integrated and by all account they're easy to replace! Which it was, but...
I got a new one of these, swapped out the upper and lower bearings (even compared them to the old ones and they were identical in size and shape) and rebuilt the whole stack. The problem now is that if I tighten the top bolt enough to stop any play when I have the brake on and jiggle the bike, then it's too stiff to steer! If I loosen it off so that the steering is ok, then there's play in the fork!
It's really odd - all I replaced were the two bearing units and the compression ring. All the other stuff is the same; I didn't want to use the new style upper bearing cover that came with the new headset as I wasn't sure it'd fit my steerer length.
Is it a case of book into the LBS or does anyone have any ideas?
Thanks!
Thanks!
