Hi I want to fit a FSA carbon pro Chainset to my Cube Agree GTC Pro, the FSA uses an Isis bottom bracket and the Cube has a BB30 can anyone tell me if this will fit and if I need any adapters etc.
I've recently used the same sleeve design to convert my BB30 to Hollowtech II. Easy enough to fit with a simple press and it solved my BB woes instantly
I want to change it as the compact crank that came with the bike is worn and rather than change the rings I thought I would upgrade. is the isis bottom bracket better than the BB30?
isis will work perfectly well, but is not really an 'upgrade' in the sense that it is an older standard. Some might argue it is actually a 'downgrade'. Either way, it would be far easier - and more logical - just to change the rings.
